Crankcase breather cover - plastic clips
I'm trying to track down a part number for the plastic clips that hold the sensor in to this opening.
Old 10-28-2013, 03:51 PM
Check with Timmy2 on the Pelican Forum. He builds harnesses.
Bruce
Old 10-28-2013, 04:49 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Do you mean the plastic nubs that are inserted into the holes in the breather housing hose neck? That's Porsche's terrible attempt to make a hose retention "bead" on the smooth casting of the breather housing. Those plastic inserts oil harden and get brittle with time, falling apart. You'd be better served putting an appropriately sized aluminum rivet into each of the holes
Kevin L
'86 Carrera "Larry"
Old 10-28-2013, 06:03 PM
