930 3.4 Engine Rebuild (lots of pics)
Hi Guys
I have decided to chronicle my engine rebuild. I performed a leak down test,
and discovered cylinders 1 & 5 were leaking 20% and 30% respectively.
Engine was running strong, but did make a phat phat phat sound.
I will be getting Mark Henry to do the heads for me. He will also be giving me a hand with the re-assembly.
Axles have been bungie tied, and I have a plastic bag around each hub.
Engine Out
Electrical wires disconnect
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 11-03-2013, 02:41 PM
Old 11-03-2013, 02:45 PM
Old 11-03-2013, 02:48 PM
Coils Off
Tins Off, Muffler Off
Old 11-03-2013, 02:54 PM
Wires Disconnected Oil Pressure Sender
Turbo oil feed disconnect
Waste Gate Removed
Old 11-03-2013, 03:02 PM
Pressure Switch disconnect, Temperature Sensor disconnect
I removed fuel distributor, throttle body, intake manifold as one assembly.
Throttle Linkage plate removal
Old 11-03-2013, 03:12 PM
Shroud Pulled Up
Left Side
Right Side
Turbo Feed Line Disconnect
Old 11-03-2013, 03:34 PM
All head studs appear to be intact. Looks like 993 studs were installed at some point.
Head Gasket Leak Cylinder #1 - 20% leak down
Head Gasket Leak Cylinder #5 - 30% leak down
Old 11-03-2013, 03:40 PM
Missing one shim
Old 11-03-2013, 03:43 PM
Removed nut off back of alternator to expose alternator wires.
Alternator wires disconnect.
Alternator removed
Long block
Old 11-03-2013, 03:48 PM
Let the cleanup begin. Clutch removed.
Getting ready for engine stand.
Got my 2 neighbours to give me a hand lifting it onto engine stand.
Old 11-03-2013, 03:56 PM
Exhaust nuts came off with very little drama. I mixed up some ATF and acetone.
Sprayed nuts, and let it sit for about 4 hours. Cracked the nuts with no issues.
Previous owner had used copper nuts. A few of the exhaust studs came out.
Exhaust off
Large crack on exhaust heater box. Need to get this checked out.
Old 11-03-2013, 04:02 PM
Cam case oil feeds removed.
Cam Bolt Removal tool ordered from our host.
Cam Cases Exposed
Old 11-03-2013, 04:08 PM
Plan on removing the cam bolt and chain cases tomorrow night.
Question. Do most of you guys follow the Bentley procedure or Wayne's procedure?
The Bentley procedure suggests that the rockers for both intake and exhaust be removed. Wayne's procedure suggests that the valve lash adjustment screw be backed off. I guess I need to remove the rockers anyway. Let me know your thoughts. Also do you remove the cam towers with the heads?
J
Old 11-03-2013, 04:20 PM
Also what is the best way to remove the tensioners? Compress the plunger. Lock 3mm locking pin, remove bolt. Remove assembly?
Old 11-03-2013, 04:26 PM
Turbonut
Raceboy's Avatar
What kind of cylinders do you have there? Is it me or why there are no cooling fins?
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 11-04-2013, 12:38 AM
Cylinders are Mahle 3.3 Turbo cylinders. Fins are on the bottom exhaust side.
Old 11-04-2013, 04:35 AM
DSPTurtle's Avatar
Nice work so far JPilcher! You can back off the screws and pull the entire assembly off the engine without removing the rockers, etc. (heads, cam carrier, and all this little parts still attached) It is a little easier to remove everything and keep track of it while working on the bench. As for the tensioners, you probably won't get the pin in there until you are ready to reassemble. A little gumption and some finesse and you will be just fine. Keep track of the shims on the cam sprockets. Slow and steady wins the race. Do you plan on splitting the case or just a nice top end rebuild?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-05-2013, 06:23 PM
Tonight I went ahead and removed the rockers as per the Bentley manual.
Bagged and tagged the rockers. I will try and get some pictures uploaded.
Rockers were in not bad shape. Bronze guide had a little wear, but nothing too severe. Has anybody used the RSR seals?
My plan at this point is to do a full rebuild. I ve read a lot of horror stories
About top end rebuild that have gone bad.
Old 11-05-2013, 07:29 PM
911 2.2 T targa
RSR seals are a cheap and easy upgrade to prevent oilleaks from the rocker shafts. I sea no reason why not to do it.
Keep those pictures coming!!!!
Old 11-06-2013, 01:10 AM
