Easy HP
How many times have we heard "speed costs money, how fast do you want to go?"
Our 1975 911s with a 3.0 CIS transplant runs ok, but another 100 hp would help. My sense is to pull the heads, check the piston and rings, grind the valves, but while we are in there ........ Any and all suggestions are appreciated. |
Size matters.
Go big or go home...?...LOL The fastest way to improve HP is to enlarge the size of the engine...it also does not effect reliability as much as raising comp ratio....wild cam...etc. Bob
Bob Hutson |
Yes, increasing the displacement is generally the simplest. That said, perhaps a 3.6 is in order. If so, is it a simple/possible conversion to go with the existing CIS system? Or switch the entire system to Motronic?
How about a NOS nitrous system for easy HP
911 SC -83 Coupe Last edited by mv70; 11-02-2013 at 06:09 PM.. |
Huge money to get to 3.6
Air Medal or two
a turbo, no IC, and a couple pounds of boost will make you happy for a little while
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Spend an afternoon reading and seaarching these forums and threads. Your quiry is not unique therefore has been answered many times....in different ways.
How about a 3.2L short stroke with PMOs and electronic ignition -- a friend did this - runs
like a rabbit chased by a coyote -- about 220 RWHP - short gear 901 box . . . Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
easy to build, cheap-ish, and has been dead nuts reliable in spite of being run. hard.
3.0 dyno day - a pleasant surprise took my SWB drag racing today......... and did someone mention nitrous ![]() new go-fast goodies for the SWB, hee, hee. hee |
