1984 3.2 head damage
Not sure how or when this chip out of the edge happened, but is this damage terminal? All the other heads are in good shape.
Not optimal but I wouldn't lose sleep over it
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Sounds good, thanks. If I happen to stumble into a few hundred extra bucks maybe I'll consider replacing it with a good used one (if I can find one) just to be optimal.
The sealing surface is in the Carrera cylinders and the nick is outside of the seal.
Bruce |
You should be good.
"Simplicity is supreme excellence" - James Watt |
| Tags |
| 1984 carrera , damage , heads |
