993 Throttle Cable Details
Can someone point me to a parts diagram that shows how the throttle cable is plumbed and installed at the engine on a 993? The cable passes through the rear engine tin, goes up through a bracket with a large hole in it, and finally ternimates at the throttle crank. I need to see what types of grommets pierce the rear engine tin and what surrounds the cable as it passes through the bracket that is installed about three inches directly below the throttle bell crank.
I've looked for over an hour and cannot locate any drawings/photos that show how the cable is rigged where it terminates on the engine.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 12-05-2013, 07:16 PM
