Port sizing for 3.0 race motor
Trying to finalize some details for my rally car and wanted to help solidify some port sizing. Current specs so far are 3.0 95mm JE 10.8:1 pistons, 46mm itb's, twin plug, arp rod bolts and stock rods, and more than likely DC60 cams... I was planning to port the heads to 40mm intake and 38mm exhaust...
LP
Old 01-13-2014, 06:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
LP
Port shape is more important than size but your formula is pretty close.
We built 3 rally engines for a series in Europe with almost identical specs (10.4 rather than 10.8). One actually learned to fly winning the championship the first year.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-13-2014, 07:56 PM
Good looking trio... My 911 won't be ready for the Rally America season opener Sno*drift in two weeks, but I will be flying in my old open class mitsu. I hope to have the 911 ready by late 2014. Oh and my wife is co-driving!
Old 01-13-2014, 08:26 PM
Straight shooter
Lapkritis's Avatar
Which # do you have for the VR4? I had #1974 (white like yours) and sold it off to Connecticut about 9yrs back. Heck of a sleeper with a ported o2 housing, 3" turbo back and the frequency valve bleeder mod.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-13-2014, 09:31 PM
Im pretty sure its #241... I sold it a few years back, but am driving it at Sno*drift in two weeks... Car made 300hp 360tq on 34mm turbo restrictor @ 18 psi and overall a good rally car despite a slow steering rack and crapy ratios for a restricted rally motor.
PRS rally car - a set on Flickr
Old 01-14-2014, 04:38 AM
Straight shooter
Lapkritis's Avatar
Just flipped through your Flickr album - gorgeous build. I used mine for commuting and time-trial ice racing with long term plans/pipe dreams to build out as you did. One trip to a 1/4 drag in Quebec and killed my second gear synchronizer... that's when we decided to part ways.
Old 01-14-2014, 09:59 AM
