peppy's Avatar
I cut the front fuel lines.....how to tell which is return
Yep, I cut them both off
I have a fuel leak in one of the lines and was just going to replace the rubber ends. Is there an easy way to tell which line is which? I was thinking of loosening the fuel filter and blowing air in the lines.
Anyone ever done this?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 11-03-2013, 08:50 AM
Is the fuel pump in working order?
Did you try clicking the ignition on for few seconds and see which hose the fuel comes out of?Put the fuel line ends in appropriate containers,have assistant turn key while you observe?
Old 11-03-2013, 09:35 AM
peppy's Avatar
yes fuel pump works but I cut the fuel line that goes to it.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-03-2013, 09:40 AM
where did you cut it?Between the tank and the pump?
Old 11-03-2013, 10:19 AM
peppy's Avatar
I cut them after the fitting on the plastic line.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-03-2013, 10:24 AM
Sorry obvious after last post you did cut tank to pump lines.My car is a 1970 and i dont think my fuel delivery system will be of much help if this is for your 84 targa.I am sure someone in the know will chime in
Old 11-03-2013, 10:28 AM
The line that comes out of the bottom/center of the fuel tank is the one that goes to the fuel pump. I think the return line goes in on the left side of the tank. Don't know where the fuel pump is in your car to tell you which line goes where from there.
-Andy
Old 11-03-2013, 08:07 PM
peppy's Avatar
I'm sorry, I didn't explain very well. I know the hoses between the pump and the tank. My issue is with the ones coming through the tunnel from the rear of the car. Both of the lines look the same now that I have cut their respective fittings off.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 11-04-2013, 05:29 AM
Go to the front of the car, look for the line coming off the fuel pump, this is your pressure side, follow the line were it goes into the tunnel, just behind the steering rack. Mark it with something, go to the back of the car and note the position of both fuel lines, also marking them for reference. Go back to the front of the car, pull about 1/2 inch forward on the pressure line, they will slide in the rubber grommets. Go back to the rear of the car and note what line moved forward, this is your P-side and the other is your R-side. A little shot of WD-40 on the grommets help the lines slide.
Dan
1985 Porsche 930, K-27, B&B exhaust, Tial WG, ER suspension, money pit.
"We are a bullet now - except faster"
Old 11-04-2013, 06:43 AM
BoxsterGT's Avatar
Porsche Crest
Here's a shot of the rear lines exiting the tunnel.........
The line on the right side is normally the feed, the one on the left side is normally the return. Unless......someone has switched them during a replacement. These fittings are M14 Male Euro Flare and are permanent to the Polyamid tunnel lines.
What exactly did you cut off? The rear hardlines (911SC or Carrera) can simply be disconnected from the tunnel lines.
Len
Old 12-27-2013, 04:56 AM
peppy's Avatar
I cut the front lines as they came out of the tunnel. I have since figured it out and am back on the road.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 12-27-2013, 11:59 AM
BoxsterGT's Avatar
Porsche Crest
Glad you figured it out yourself as I was getting confused trying to follow this.
Just so others may understand the layout, at the front the original lines look like this.........
I expect you cut back the crimp sleeve and the rubber hose like this.........
and replaced it with new E-85 rated fuel injection hose and proper Norma or Oetiker type hose clamps.
Len
Old 12-27-2013, 02:32 PM
peppy's Avatar
That is exactly what I did. I just cut them both at the same time.
Sorry for all the confusion.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 12-28-2013, 08:44 AM
