Bonehead move on crank install
During installation of my crank assembly, I made a stupid mistake. Installing crank I couldn't figure out why it wouldn't seat in the bearings. Pulled crank out, then I realized I hadn't lined up the #8 bearing with the dowel pin mark I made. I was just too nervous. I didn't think about it. Ended up scratching the left side of the outside of the #8 bearing. Anything I can do except buy another bearing and start again?
Old 12-24-2013, 01:51 PM
Use it as is. Glue it in as per Henry Schmidt and move on.
Tell it like it is or don't tell it at all.
Old 12-24-2013, 03:19 PM
Thanks lindy, and Merry Xmas!
Old 12-24-2013, 03:31 PM
Hi Mitch1
It's probably too late, but you could put a VERY thin coating of Loctite 574 on there.
dmark9
P Fix It | Porsche 964 | Repair & Maintenance Videos
Old 01-08-2014, 10:17 PM
