Question about MFI fuel pump
Everybody is talking about the bad China MFI fuel pumps and that nothing good is available. Now that I nearly finished my race engine (first time with MFI instead of carbs) I was wondering why not take for example a SC pump and the PMO fuel pressure regulator with return line and adjust the pressure at 1 bar. The engine need a fine calibration on the dyno anyway.... Am I thinking to simple?
many thanks for you input!
Old 01-09-2014, 02:42 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Your idea is exactly what we do. The only change you need is a different gauge on the regulator. We use a 30 lb instead of the 15lb gauge that comes from PMO.
We also like to use the 74 CIS pump .
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-09-2014, 03:04 PM
Thank you very much for your answer. Do I understand it correct that you set the pressure at 2 bar/30 lb?
Old 01-09-2014, 03:09 PM
