LinkBack | Thread Tools | Rate Thread |
Certified Pre-Owned
What's the best way to handle this? (separate the cam tower from the heads in-situ)
Hi all, continuing on from my thread here: ThreeBond 1194 between the heads and cam towers...yay or nay? I am now at the point where I can separate the tower from the heads. I'd like to leave the heads alone, meaning the head studs/heads etc are to be left in place. What's the best way to pry/beat/extract the tower from the heads?
My leak was near the red arrow. Thanks
'84 Carrera Coupe |
Straight shooter
There's thick meat above the exhaust port. Always gentle with aluminum and be careful not to pry against a fin... which goes without saying. Just make sure you have all the nuts off for all heads first. Triple check.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Use a dead blow plastic faced hammer on the corners right by your arrow (or a rubber mallet). They should pop off pretty easily.....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
You still have the rockers in place so you cant get to all the nuts.
Bruce |
Wer bremst verliert
I know you don't want to hear this, but my opinion is you will be better off doing it properly and taking the towers off, rockers out, etc.
I'd be concerned about contamination of the engine when doing it like you are suggesting. 574 sqeezeout blobs can break off and float about in your oil after you seal it up. You also need to get fresh sealant to every mating surface, not just the leaking part. You MIGHT be ok doing it your way, but its not what I'd do on my own motors.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Certified Pre-Owned
Ah, forgot about that...that would explain it.
'84 Carrera Coupe |
