Cam ID
Hi Guys
Wanted to see if anyone recognizes these cams. AN-964 Drivers side cam,. AN-964 cam is marked 1.95. I take it that this is the cam timing? I forgot to check the timing when disassembling the motor.
Does 1.95 cam timing seem reasonable?
Are these Andial Cams?
Thanks in Advance.
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 01-12-2014, 06:54 AM
