Norwegian 911 E Coupe
DP911-70-2,7's Avatar
SC engine... 40 Webers and E cams
Hi ...
I have a 1980 911 SC Euro engine...188 hp. It has two bent valves and it need an "rebuilt".
I like to change to 40 mm Weber's, and i have some E cams lying on the shelf. Can i use them....or will this just be wrong ?? Is it better to go for the stock SC cams when using Weber's ??
B.A
Norway.
1970 911 Targa
1985 928 S2
Old 01-14-2014, 10:45 AM
E cams etc.
If they are really E cams from a 2.0 or 2.2 they won't fit on anything bigger than a 2.7. also if you still have cis pistons they will probably interfere with real E cams. If you want to spent the coin to get pistons with sufficient clearance for higher lift cams, ie JEs etc. and you put webbers, E cam exhaust etc. you will have a fine engine but it will suck 25% or so more fuel. best Henry
Old 01-14-2014, 11:48 AM
Ok...thx. The 1973 E cams i will sell then...
More fuel, puhh... who cares. I live in Norway.... have my own oil rig
So, how many hp do i get from just change to Weber's and old style exhaust...??
1970 911 Targa
1985 928 S2
Old 01-14-2014, 01:34 PM
A 1980 Euro SC with 40mm weber's and early exhaust should give at least 230HP. You will need to recurve the distributor or use a 78-79 distributor. You should use 30 degrees of advance at 5000 RPM.
If you "blue print" the engine so you get an actual 9.8 compression ratio you can get a little more. 46mm carbs will get you about 5-10 more. You will need to rev to 7000 RPM to get the full HP numbers. Set the cams at .9mm for max power.
-Andy
Old 01-15-2014, 10:13 AM
Thank you Andy....
Weber carbs have been pretty expensive... so i will use my 40 Weber's..... thats ok by me.
B.A
1970 911 Targa
1985 928 S2
Old 01-15-2014, 01:16 PM
