nene's Avatar
Valve loose again???
I adjusted my valves (using the Back-Side method) to my 3.2 about 200 miles ago and made sure they were nice and tight and to spec. I recently started feeling the car shaking a bit when at idle, and also some excessive noise. I opened up the passenger side valve covers and starting taking the valve-gap measurements, and to my surprise, they were all loose!! WTH!!
Using both of the required Go No-Go gauges, I was able to slide both of them, one at a time with no resistance at all!! What is going on here??
Note- according to the PO, the engine had been "overhauled". So here is my question, when a engine has been "overhauled" or refreshed, would this cause
"general" items to loosen up? I did have one loose head-stud last time I adjusted the valves, so it makes me wonder??
Thanx,
Serge
Old 04-12-2014, 08:03 PM
pete3799's Avatar
Don't know......but adjust them again.
.0025 go .003 no go....... works for me.
Pelican Technical Article: 911 Valve Adjustment - The Backside Method
Pete
79 911SC RoW
Old 04-12-2014, 08:39 PM
Did you adjust you valves with the engine stone cold?
And have your loose, subsequent measurements been taken with the engine stone cold?
I haven't measured my valves when warm, but others report that when warm the valves loosen. So that may be your issue.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-12-2014, 08:42 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Were they quiet after the first setting? If so, my thoughts are: perhaps the settings changed because the lock nuts were not tight enough or something is wearing in the valve train - cam lobe or rocker face. Rocker shafts moving could be an issue too. Good luck.
Old 04-13-2014, 08:49 AM
nene's Avatar
Thanx for the input - First, I am familiar with the process and yes, I adjusted the valves in the "Cold-Stone" state. It sounds better and they weren't too loud, but I wanted to just check them. I really don't think the Cam Lobes or Rockers have worn that much in 200-300 miles.
Any other thoughts??
Sergio
Old 04-13-2014, 09:17 AM
