p to v clearance
Is it possible to have too much piston to valve clearance?I wasn't able to touch the piston with the valve screwed all the way in at the proper crank positions.Thanks,t.c.
What were you building?
Bruce |
a 2.7 8.5 cr
I don't think it's possible to have too much clearance, but it is possible you did the check wrong.
-Andy |
Contrary to what i used to know..The valves are closer to piston at mid stroke then any other point
-Andy |
Yes, at the overlap
What's your deck height set at?
| All times are GMT -8. The time now is 08:30 AM. |
