p to v clearance
Is it possible to have too much piston to valve clearance?I wasn't able to touch the piston with the valve screwed all the way in at the proper crank positions.Thanks,t.c.
What were you building?
Bruce |
a 2.7 8.5 cr
I don't think it's possible to have too much clearance, but it is possible you did the check wrong.
-Andy
72 Carrera RS replica, Spec 911 racer |
Air Medal or two
Contrary to what i used to know..The valves are closer to piston at mid stroke then any other point
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
-Andy
Air Medal or two
Yes, at the overlap
What's your deck height set at?
