carrerarsr65
oil pump cleaning??
79 3.0 sc oil pump ,when I take this apart to clean it,should I use any type of sealant where the two oil pump case halves meet, lost a con rod bearing and want to as thorough as possible al from mass
before the little engine problem, hahaha
Old 06-04-2014, 07:20 AM
Every pump Ive taken apart didnt have any noticeable means of sealant in the pump. Both my 993 and 930 turbo pump where like that. Just make sure to mark the rotors to make sure it all goes back together the same. Work looking at the scav side to see if there as any damage. GL.
Old 06-04-2014, 08:28 AM
OT: Great color- what's it called?
'90C4
Old 06-04-2014, 10:16 AM
TheSt|G's Avatar
Looks like Minerva blue.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-04-2014, 11:40 AM
Walt Fricke's Avatar
No sealant.
Old 06-04-2014, 02:31 PM
0396's Avatar
If your motor lost a con rod and there's a possibility that it could be scared.
You might as well send that pump to Glenn Yee Racing in San Dimas Calf for 1) for cleaning 2) mods to increase overall flow.....blue printed.
Fyi
Old 06-04-2014, 03:52 PM
