3.6 to 3.8L
Hi,
anyone done this and what is the best way to do it?
what parts do i need to change if i am using a 964 3.6L c2 engine.
I am intending to get it up to 3.8L 993 pistons.
Anyone uses CP Pistons or mahle.
Can we just buy it from this 2 manufacturers direct and do it with our local mechanic.
Must i upgrade my cams for the car?
can the ecu handle this with a dyne tune or must i use a motec or other standalone ecu
Old 06-30-2014, 12:22 AM
Hi,
The best way to do this is by using the thick-walled, Mahle 102mm P/C's. The case spigots will need to be machined for these.
You can use stock or SS cams. The ECU will need a different chip, for certain.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-30-2014, 09:09 AM
Sboxin's Avatar
Agree with Steve - - -
For a 1992 964 3.6L to 3.8L race engine
- We used EBS Racing in Nevada for JE pistons/cylinder refurb
- We used WebCams for 20/21 cam rebuild
- And, we used Steve Wong for custom dyno chip
IMHO, if your 3.6L does not need a rebuild I would not bother with the 3.8L upgrade
it can be very expensive
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 06-30-2014, 05:10 PM
CBRacerX's Avatar
Here you go!
Another 3.6->3.8 Rebuild Thread...
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 07-02-2014, 05:39 PM
