3.6 to 3.8L
Hi,
anyone done this and what is the best way to do it? what parts do i need to change if i am using a 964 3.6L c2 engine. I am intending to get it up to 3.8L 993 pistons. Anyone uses CP Pistons or mahle. Can we just buy it from this 2 manufacturers direct and do it with our local mechanic. Must i upgrade my cams for the car? can the ecu handle this with a dyne tune or must i use a motec or other standalone ecu |
Hi,
The best way to do this is by using the thick-walled, Mahle 102mm P/C's. The case spigots will need to be machined for these. You can use stock or SS cams. The ECU will need a different chip, for certain.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Agree with Steve - - -
For a 1992 964 3.6L to 3.8L race engine - We used EBS Racing in Nevada for JE pistons/cylinder refurb - We used WebCams for 20/21 cam rebuild - And, we used Steve Wong for custom dyno chip IMHO, if your 3.6L does not need a rebuild I would not bother with the 3.8L upgrade it can be very expensive Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
