Weber carbs setting 2,0 Solex
Hello,
can anyone tell me which jets, emulsion tubes, venturis,... I should take for a 1965 2,0 engine with solex cams and 40IDA Weber carbs? Many thanks, best regards Malte |
Malte - Hi
Venturi - 30mm Main Jet - 125 Air Corrector - 180 Emulsion Tube - F26 Idle Jet - 55 Idle Air Bleed 110* Should get you close. * The size of the bush fitted into the carb may differ depending on the body you have. It may be worth think about fitting tuneable Idle Air Correctors We have a new system for our carbs - We pull the bush out of the carb and slot drill a shuled so we can fit a short M4 Timesert http://i197.photobucket.com/albums/a...ps88a125b6.jpg We can then screw in a calibrated jet to a controlled depth as the jet we use has a small shoulder http://i197.photobucket.com/albums/a...psc66fff38.jpg http://i197.photobucket.com/albums/a...ps66bd6f30.jpg |
Hello Chis,
thank you for the answer and sorry for the late reply! -I was in Essen (Techno Classica) the last week. I have your idel air bleed/callibrate screws in my 46 webers and they are working very good! |
| All times are GMT -8. The time now is 11:21 PM. |
