Weber carbs setting 2,0 Solex
Hello,
can anyone tell me which jets, emulsion tubes, venturis,... I should take for a 1965 2,0 engine with solex cams and 40IDA Weber carbs?
Many thanks, best regards
Malte
Old 03-27-2014, 12:40 AM
Malte - Hi
Venturi - 30mm
Main Jet - 125
Air Corrector - 180
Emulsion Tube - F26
Idle Jet - 55
Idle Air Bleed 110*
Should get you close.
* The size of the bush fitted into the carb may differ depending on the body you have.
It may be worth think about fitting tuneable Idle Air Correctors
We have a new system for our carbs - We pull the bush out of the carb and slot drill a shuled so we can fit a short M4 Timesert
We can then screw in a calibrated jet to a controlled depth as the jet we use has a small shoulder
Old 03-27-2014, 03:03 AM
Hello Chis,
thank you for the answer and sorry for the late reply! -I was in Essen (Techno Classica) the last week.
I have your idel air bleed/callibrate screws in my 46 webers and they are working very good!
Old 03-31-2014, 02:57 AM
