Std Valve springs or High performance?
I am building a 3.4 Race mild race engine JE 10.5, GE60 cams, 46MM PMOs
revving to 7000 rpm.
Should i fit aftermarket valve springs? Titanium valve keepers?
Bruce Anderson s book states "none of the aftermarket valve springs are as good as the original"
Old 03-29-2014, 04:55 AM
304065's Avatar
7000 I would use stock springs that you have tested
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-29-2014, 04:58 AM
What about lighter keepers?
Old 03-29-2014, 05:05 AM
Have you had experience knife edging cranks? Pros and Cons
Old 03-29-2014, 05:06 AM
304065's Avatar
Doesn't seem to be a drawback to lighter valve train except the price.
'81 R65
Old 03-29-2014, 07:35 AM
JMHO,......
New stock springs are not as good as they used to be and older ones have usually lost some seat pressure due to long-term fatigue.
Race engines NEED all the over-rev protection they can get to help prevent piston-to-valve contact and this means GOOD aftermarket springs (there is some junk out there).
Further, the 3.0 and later retainers are sintered metal which fractures when valves contact pistons, even lightly. We always use Ti retainers in any race engine that will see 7K or more.
Good springs & Ti retainers are simply insurance, just like rods & rod bolts.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-29-2014, 12:21 PM
Hi steve,thanks for your input.
What brand springs and Ti retainers do you recommend ?
I am wanting to run this motor as a one plug (programable MSD) using JE 10.5 :1 pistons and the GE 60 cams 1.5/8 headers straight out the back.46 pmo ,i can run any fuel I like ,
What octane & and advance would u recommend ?
Should I balance this engine? What port work ? The car is used for many type of events from street racing,hill climbs, track days etc. Not road registered . 5 gears 930 LSD 1070 kg wet inc driver.
Many thanks for your help.
John
Old 03-29-2014, 04:37 PM
John
Hi John,
Contact me directly (off forum).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-29-2014, 07:11 PM
Banned
Shrick springs...top notch.
Old 03-29-2014, 07:48 PM
