SchnellSchweitz's Avatar
Backup light switch pin (homemade)
OK... as many of you know, the backup light switch pin is no longer available from Pelican. When I performed my transmission rebuild a few years ago, I lost my pin and followed the directions provided in the link below.
This method worked like a charm until a few weeks ago when my backup switch kept shorting out my turn signal fuse. Anybody else have this issue?
Perhaps I got the pin too long??? I believe I made it the extra 7mm as described.
Just curious if anybody found a solution.
Thanks in advance.
Reverse Light Switch Woes
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 04-14-2014, 07:55 PM
Just a quick update on my backup light switch. The old one is shown below. You can see the damage to the switch. The button surface (inside hole) is actually worn into a groove.
My hunch is the groove became too deep and the pin wouldn't actually push the button far enough to reach the contacts or the switch was damaged by a pin that was too long. New switch works great. I used an extra washer to give it a little extra space.
Old 04-20-2014, 10:04 AM
