Newbie questions about high CR and twin plug conversion
Good day,
I'm afraid that I've been away from Porsches for way too long! I have searched on this topic, but I really don't have the 'vocabulary' to understand a lot of what I read. So, I'm going to expose my ignorance and ask a couple of questions, not hoping for 'in depth' answers, but more for general guidance and information. So, here goes... I have just purchased a 1987 Carrera coupe, just over 100,000 miles and in absolutely superb condition. A few years ago (some 6,000 miles ago) the previous owner converted the car from 3.2 to 3.4, using JE pistons (10.5:1 CR), cams reground to 964, and SSI exhaust. From what I read (and the little I understand!), I learn that the 10.5:1 CR with single plug heads is problematic... tuned to be 'safe' results in less-than-optimum performance. So (finally my questions!); what is the simplest route to twin plug conversion? Can I simply have the heads (and valve covers) modified, bolt in a JBRacing twin distributor and go... or, is there more work needed? Alternatively, should I just change the pistons to 9.5:1 CR and forget the twin plug idea? Full disclosure: I have the title, but not the car... Intercity will be bringing it to me in a week or so. Thanks for indulging an old geezer! Rob |
The easy part is drilling/tapping the head and putting the spark plug in (assuming you already have the engine apart).
The expensive part is the twin plug distributor. Many people go with a crank fire or other form of electronic ignition to avoid the distributor cost. You could also do a 964 distributor. Or pay for the correct looking 12 terminal cap type. |
Or, should I just lower the CR to 9.5:1 / Rob |
I'd skip the distributor and go right to an xdi system from Clewett. You can google that.
http://dorkiphus.net/porsche/attachm...1&d=1395771098 |
We are doing this now...but very slowly. We have the 964 distributor, twin plug heads, and an Andial Motronic splitter. The Motronic can't run the twin plug by itself.
| All times are GMT -8. The time now is 12:37 AM. |
