Oil Leak - Help
I am trying to fix a small persistent oil leak on my 3.0 RSR spec motor. The case is a '79 SC Al case. I have traced the leak to the junction between the cooler and the case as shown below.
![]() I removed the cooler and pressure tested it to find no leakage. The case surface did show some sign of leakage but the source was not apparent. The fresh oil in the pic is drippage from the case to cooler seals that occurred after the cooler was removed. The area behind the through bolt washers was clean, dry and sealed with RTV. ![]() I replaced the (3) case to cooler sealing rings and reinstalled the cooler only to find the same leakage. I recently read a thread here regarding case porosity in this region and the need to seal it with some type of sealant. Can anyone expand on this and possibly explain where to seal and what type of sealant to use?
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Straight shooter
There is a service bulletin for the 7 o'clock indent in the cavity behind the cooler on the case to be epoxied. Looks like yours is yet to be done.
Edit: JB weld or similar with a thorough cleaning should do the trick.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Looks like an O ring leak......maybe try the green Viton O rings.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Tom, there is also some recent info that the replacement cooler seals don't have the same dimensions as the originals, causing a leak. I supposed you used Charlie's? After my RMS fiasco(s) I won't touch anything made by Reinz. Anyway, I would get a handful of seals from different suppliers and mic them up. Also depth mic the case recess and the cooler.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
carrerarsr65
jb weld
it seems that the jb should do it for you , aggod cleaning first with some brake clean spray to degrease,also make sure your work area is at least 50 degrees s it sets up right, good luck al
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thanks for all the input.
Interestingly, the area identified in the service bulletin looked pretty dry when I removed the cooler. Also I am using the red seals, procured from a local, very experienced Porsche engine builder. I think I will remove the cooler, clean up the cavity, apply the JB weld per the service bulletin and use some Curil-T on the seals.
Tom, on mine, the oil leak was quite obvious as coming from the known casting issue. I wonder if the leak is from one of the case through bolt O rings, (at the acorn nuts)?
Dave |
The acorn nuts and beveled washers were completely dry when I removed them to check.
Well Tom, that's good that they were dry, eliminates that possibility. Seems to be pointing more strongly to the seals, good luck and post the final solution.
For the longest time my car had a mystery oil leak in that region. Only recently discovered if I keep the oil level in the middle of the gage when hot (not toward the top) the crank case breather hose would not weep and cause oil to run down the oil cooler and the back of the engine.
If all else fails run half a qt less oil than usual and see what hopefully does not happen. Chris 73 911 E |
Straight shooter
I can see the hole in his second picture. Look at the indent - you can see the edge of the break.
Pressure test.........
Tom,
Could you pressure test the engine oil cooler and do the immersion test before coating it? Just curious if you could detect the microscopic crack/s with a pressure test. Tony |
Tony
I pressure tested the cooler and found no leaks. I JB welded the indent in the case and used Curil-T on the cooler seals. Have not tried it out yet.
