cylinder head/cam housing
having trouble separting cylinder heads from cam housing on the 3.0 six engine winter project that carryed over to spring. anybody out that can share a working method , frist time for me at this. thanks john
Old 05-02-2014, 11:49 AM
You have to have all rockers out and the cam too.
I slip a screwdriver between the head and carrier, top and bottom, and twist breaking the seal.
You might put a nut back on a couple studs and tap them to get movement.
Bruce
Old 05-02-2014, 11:52 AM
thanks all try to tap the studs with the nut on them . i got one side loose by prying . the other side is realy stuck. john
Old 05-02-2014, 12:07 PM
If the heads are still bolted to the motor, you need tap the cam towers loose using a big rubber mallet or brass hammer on the four corners of the cam towers
Old 05-02-2014, 02:20 PM
