OK to drill 3.0 case for SSI mounts?
Installing new SSI's on my rebuilt 1983 SC 3.0 engine and there are no threaded holes to mount the support tabs on the SSI's. I have the case with the sump plate. There is a boss cast into the case on both sides, but one side (#1, #2, #3 side I think) looks like I could easily get in trouble by drilling too deep for an 8mm thread.
I'm sure everyone who has backdated has run across this, but does anyone have any tips or cautions? Not sure if I should use studs or just tap for a screws. Any thoughts welcome. Thanks.
Old 06-04-2014, 11:22 AM
Alan L's Avatar
I have no experience installing SSIs, but a friend did some on his '77 s. Had no issue.
I would not go drilling into the engine case, unless someone here posts that this is normal. The risk is too great.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-04-2014, 04:45 PM
Walt Fricke's Avatar
Well, the simplest thing is to ignore this, as fastening the heater box part to the case is not necessary. Just another thing to mess around with getting things lined up.
But I took a look at a 1976 3.0 case I have handy. On each side you can safely drill down to the level of the top of the nearby casting. No need to overdo it.
Me, I'd tap and use a short bolt, if I were so inclined.
Old 06-04-2014, 05:35 PM
SSI installation......
The drilling for the SSI tab on the engine case during installation was never discussed or mentioned by people who had installed or used SSI. But I became curious and started asking around.
The consensus I got was not to bother drilling the case because the additional fasteners that require drilling was not necessarily needed. As you can see from the above picture, one of the tabs was flattened in preparation for the drilling operation. The idea of drilling holes to the crankcase did not appeal to many and decided to leave them alone.
Tony
Old 06-04-2014, 08:19 PM
Retired Member
Charlie V's Avatar
I wouldn't. Have SSIs on mine for the last 10 plus years and over 75,000 kms with no issues.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 06-04-2014, 09:23 PM
Thanks for your replies, but I was itching to finish my install last night, and trusted the engineers (and bean counters) who were thoughtful enough to keep the extra material in the case, apparently for this purpose. I went ahead and drilled and tapped 13-14mm deep and locked in some short studs. Worked well and SSI's are now fully supported.
Old 06-05-2014, 12:24 PM
