BoxxerSix's Avatar
Valve lift cam timing specs for M96.70?
Does anyone know where I can locate cam lift timing specs for a 996 Turbo M96.70 engine, or know of someone I could possibly contact at PCNA that might be able to assist in the matter? I know they exist for the GT3, but those cams specs are a bit different than the turbo.
Some may recall that my shop had multiple $K's in factory tooling stolen(amongst other things) that I unfortunately never got replaced to poor insurance coverage on shop tooling () Tool 9661 was one of these tools and is now over $2500 to buy. Baums tool is a joke and still costs $1800+ to get from them.
I'd like to CNC my own tooling again but could use the cam specs to time a "junker" motor here first.
Can anyone help or direct me to the proper person who can?
Big thanks folks!
-Adam
Adam Hennessy
Old 05-21-2011, 08:18 PM
I have the casmshaft data and I will get you the info monday when I return to the shop.
P.S. if I forget please remind me
regards
Old 05-22-2011, 05:30 PM
BoxxerSix's Avatar
Greatly appreciated, I will do that
Adam Hennessy
Old 05-22-2011, 06:40 PM
Here you go this is directly from Porsche
Inlet opens @ 10 BTDC
Closes @ 20 ABDC
Exh opens @ 41 BBDC
Closes @ 9 BTDC
bear in mind that this is taken a 1mm lift and that the Vario mechanism would be in the fully adavanced position which according to these numbers would be 95 C/L intake and 106 exh
regards
Old 05-23-2011, 08:13 AM
BoxxerSix's Avatar
Big thanks for the info, that's exactly what I was looking for!
Adam Hennessy
Old 05-23-2011, 07:36 PM
Hey there... Any chance you might be able to help me with the same info for my 2004 996 GT3?
Old 07-26-2012, 03:13 AM
let me root around some I have changed computers and have not re installed the program
regards
Old 07-26-2012, 07:37 AM
Send a message via Skype™ to timtt
Hi racing97,
Were you ever able to dig up the 2004 GT3 timing info?
Many thanks for your help,
Tim
Old 06-01-2014, 03:26 PM
Same as #4 posting
regards
Old 06-02-2014, 08:25 AM
Awesome, thanks for the quick response!
Old 06-02-2014, 09:29 AM
