ARP head studs- Question
Are the ARP head studs magnetic or non magnetic.
The rod bolts on an engine I just opened are ARP because they are stamped but curious about the head studs which are non magnetic.
Without a definite answer, I ll have to change them out.
Thanks,
Bruce
Old 06-13-2014, 01:34 PM
Straight shooter
Lapkritis's Avatar
Non-magnetic per internet.
http://www.eng-tips.com/viewthread.cfm?qid=182729
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-13-2014, 06:03 PM
H2odiesel's Avatar
The ARP studs also differ from stock in that they have a "bullet" tip at the nut end and they use a 12 point nut.
Old 06-16-2014, 03:29 AM
