Value of 930 engine and transmission
Hi all,
I am trying to determine what the current market value might be for a well running stock 930 engine and also a 930 transmission. The short story is that I did a good amount of damage to my 930 hitting a tire wall at the track. I have not made any decisions to fix, part or sell "as is" the car. I have posted over in the turbocharging forum as well but cannot seem to get a consensus on what the mechanicals might go for. Here are the details: Appx 90k on the clock (actual unknown) Smooth running & Professionally maintained. 87 930 CIS engine-Valve adjustment, new injector blocks, new plugs, wires 3/2014. Compression test 9/2012 #1 -- 132 psi #4 -- 130 psi #2 -- 130 psi #5 -- 135 psi #3 -- 132 psi #6 -- 130 psi 87 930 Transmission (appx 90K on it. Pretty typical 930 box) with factory LSD Stock exhaust system with heat 3LDZ (appx 90k on it) Here's the link to my other thread: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/815022-need-help-pricing-due-loss.html Again, I'm really just trying to understand all my options before making a decision on how to move forward. I really appreciate all the insight and info. I am happy to answer any questions. Thanks in advance. Will |
