Wrightwood valve cover gaskets - reuse?
It is time to do my first valve adjustment after my rebuild, and while thinking about it, I came up with a question.
Can the green valve cover gaskets that come with the Wrightwood Racing gasket set be re-used? I think I originally installed them dry, and they have been leak free so far.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
if they leak when you're done, no. otherwise you lucked out. i wouldn't.
Thanks John,
If they are not intended as a reusable gasket, then I wouldn't attempt it. I know some are sold specifically as a reusable gasket, but I wasn't sure if mine were since they came in a kit. I will order a new set. Regards
I tend to reuse mine (as well as the washers & nuts) if they come off clean & in one piece. Haven't had any leaking issues yet. If there is one, it's not hard to replace the offending gasket.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
