Broken head studs
So, I pulled my 3.0 and replaced it with a 2.7 so I could fix some oil leaks. With the motor on the stand I could hear parts clinking when I turned the engine upside down. Pulled the bottom valve covers and BAM! Look what I found! 4 on the right bank and two on the left bank. I assume this is a bad thing. The engine ran like a top so this really surprised me. I am still learning about Porsche engines and haven't torn one down yet. My question is, how difficult is this to fix and can it be done in my garage? I have good mechanical skills.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 06-14-2014, 07:53 AM
Tear down and rebuild can be done in your garage if you are reasonably competent. The engine is fairly basic in design but full of odd design philosophy compared to more traditional engine layouts. Don't worry too much about the horror stories you read on this forum about engine rebuilding. Most will be straight forwards.
Old 06-14-2014, 12:46 PM
You do have to pull it all the way down to short block. Hope none are broken to case level, then the shop needs to be involved, and things get more expensive.
Do a valve job on The heads.
Now, do you want to know if the bottom has been opened?
Is your crank standard, is the centerline leaking?
Bottom end gasket set is only $50
Bruce
Old 06-14-2014, 02:18 PM
I have read a lot of horror stories about splitting the case so I don't know if I am up for that but I would have the heads done while they are off. I will take your advise flat6 and buy the gasket set.
Tom Feeney
1970 911 T
1973 911 T
Old 06-14-2014, 06:15 PM
Does everyone agree that there is no need to split the case? The motor is from a 1981 SC rollover with only 65,000 miles.
Tom Feeney
1970 911 T
1973 911 T
Old 06-15-2014, 05:11 AM
Air Medal or two
afterburn 549's Avatar
The agreement could only be if you have no other problems screaming at you.
No massive oil leaks, good leak dwn numbers, ETC
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-15-2014, 09:50 AM
We'll you don't want to be grinding out a short broke stud with the case opened. The shop will want to handle just the half if the break is below level.
Bruce
Old 06-15-2014, 11:17 AM
Air Medal or two
If you have even a little above the case to grab on to get some serious heat. Most lock tight epoxy stuff lets go at around 600 deg.
Old 06-15-2014, 11:55 AM
aquazulu2's Avatar
QuikCenter Broken Bolt Removal Tool - Standard Course (131120599605) ebay..
An excellent demonstration on youtube.. good luck..
Another essential: Elora Germany NOS Air Cooled VW Porsche Piston Ring Compressor. (371059852710)
Old 06-15-2014, 12:02 PM
