-   -   Is starter working? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/818598-starter-working.html)
dmj 06-30-2014 01:26 PM
Is starter working?
I just rebuilt my engine using your books and wanted to test the starter before I put the engine and transmission back in the car.
I jumpstarted the starter attached to the engine using my battery and starter cables, and the starter operates but the engine does not turn.
I tested to remove the starter and jump started it again on my workbench. The motor is running and the gear is turning, but the gear does not extend.. so I assume that is why it does not engage with the flywheel teeth.
Is it a problem with the starter or is it just the way i jumpstart it? I grounded it and connected the + cable to the terminal closest to the starter, not the battery connection that usually is connected which require the ignition switch.
I have. 911 SC 1980.
Best,
Daniel
afterburn 549 06-30-2014 02:08 PM
Did you jump the relay?
dmj 06-30-2014 11:37 PM
No.
There are two major terminals, the battery + connector and the one close to the starter connected to the field winding with a strap. Also, we have the flat connectors to the ignition switch (top) and the cold start injector (bottom).
I connected the battery + to the terminal connected directly to the starter field winding, bypassing the relay.
Is there another (proper) way to jump it?
afterburn 549 07-01-2014 10:54 AM
your relay is there to pull then bendix out to the teeth on the flywheel.
bypassing that -your starter will just spin freely
dmj 07-19-2014 07:35 AM
Many thanks, works great now.
boyt911sc 07-19-2014 01:25 PM
Solenoid........
You meant solenoid instead of relay?
Tony
