Is starter working?
I just rebuilt my engine using your books and wanted to test the starter before I put the engine and transmission back in the car.
I jumpstarted the starter attached to the engine using my battery and starter cables, and the starter operates but the engine does not turn. I tested to remove the starter and jump started it again on my workbench. The motor is running and the gear is turning, but the gear does not extend.. so I assume that is why it does not engage with the flywheel teeth. Is it a problem with the starter or is it just the way i jumpstart it? I grounded it and connected the + cable to the terminal closest to the starter, not the battery connection that usually is connected which require the ignition switch. I have. 911 SC 1980. Best, Daniel
__________________ Daniel Alsén Porsche Club Sweden 1980 911 SC 2013 Land Rover Discovery |
Air Medal or two
Did you jump the relay?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
No.
There are two major terminals, the battery + connector and the one close to the starter connected to the field winding with a strap. Also, we have the flat connectors to the ignition switch (top) and the cold start injector (bottom). I connected the battery + to the terminal connected directly to the starter field winding, bypassing the relay. Is there another (proper) way to jump it? |
Air Medal or two
your relay is there to pull then bendix out to the teeth on the flywheel.
bypassing that -your starter will just spin freely
Many thanks, works great now.
Solenoid........
Tony |
