Following the build! Looks great. I'm about to disassemble my heads. You said there's a shop you took them to in Richmond, VA? I'm in VA Beach so I could definitely swing by and drop them off. How much did getting them rebuilt set you back? Did you have a lot of trouble getting the rockers apart?
1971 911T Irish Green Coupe
Old 02-26-2015, 07:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
michael lang's Avatar
Thanks for everyone's opinion, I figure for what I'm doing with my car I will not go wrong with whatever set I decide to go with. They all are very good quality and will serve me well. Here's what I found pricewise:ARP $550 Raceware $495 Supertec $650. As much as I want to support Henry's business I don't know if I can swing the extra $100-$150 but that's something I have to work out on my own. My goal for this weekend will be to get the old headstuds out. Would it be wise to take the pistons off, since I have to remove the cylinders, to clean off the burnt material on the piston tops or is that really not needed? The other thing I am wondering is should I order a new set of the copper rings at the base of the cylinders against case half? they are not leaking and appear to be in excellent condition but since they are the original and I'm literally right there, I thought it might be prudent to do it.
Sebastian, my car is at Chuck's Frame Shop in Richmond. Chuck is the tech that is fixing my car's body after I was hit on the pass side exiting T9 at Summit Point Main. The head work was done by Bob Hirsch at Anchor Atlantic, Anchor Atlantic Enterprises LLC - Home Bob was really easy to work with, I told him what I was interested in, what I use my car for, what my goals were, after that he did all the work. I'm really pleased with what I got back from him. If your interested in price, I would suggest you calling him and discussing what you want. I had EBS send him the valve springs, retainers, manifold studs so there was more in parts. Plus the machine work, plus the machine work with Dema Elgin grinding and polishing the cams. It's amazing how quickly everything adds up, and my rebuild is more of a refreshening than a rebuild so it's comparatively mild as compared to most.
Mike
'89 CARRERA
#402
Old 02-26-2015, 11:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Michael, I will have to shoot anchor an email and check their prices.. right now I'm 2k in machine work alone on the case for my 71 still have to buy a set of pistons and cylinders along with all the typical stuff you need (gaskets, oil lines, etc) and the Carrera tensioner update. I think I'm going to be in this engine around 6k by the time it's all said and done.. But I'm going to spend a little more in the beginning so that way I'll have a motor that will be able to last the life of the car and should end up giving me a little more hp (original for the car is 125hp to be exact).
Old 02-27-2015, 02:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Washington DC got hit with snow this morning and then sleet and freezing rain for the remainder of the day. So while I was making lunch I went out and turned the propane heater in the garage. By the time lunch was done, I was ready and the garage was waiting for me and that engine had my name all over it.
I was able to get all of the head bolt studs out, without breaking anything and only cussing a couple of times because one of the #2 cyl intake side studs had decided to be stubborn and not want to come out.
So rather than force the issue, I moved the heater a little closer and to slowly warn the case and the stud. I decided to go work on the other side while that heated up. Worked like a charm. After I finished the #s 4,5 & 6 I went back to the last one on #2. Off it came, a lot of cracking popping and moaning but it came off. Nothing broken. Now all I have to do is wait for the studs from my friends at EBS Racing and I will be good to go. Would it have been possible to have taken the studs out without removing the cylinders? One would think that since you're only doing stud off, stud back on and there would be no issues. Or did I miss something in how these things are supposed to be put together?
Mike
'89 CARRERA
#402
Old 03-01-2015, 02:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
3.2l rebuild, the quest for more power
In my mind, I have made a lot of progress since the last post. Although it always seems like once you start getting some momentum and making real progress your life gets in the way and you have to stop.
As I previously stated, I decided to take everyone's advice and come apart with the cylinders and replace the head bolt studs. Although I have to admit I really didn't want to but I'm more afraid of what would potentially happen if I did not replace them I really wasn't interested in tearing that thing apart again.
The head bolt studs came out with no issues but not without a lot of moaning, groaning, creaking and cracking. I got them all out without any major issues.
Since I only have a metric stud removal tool I had to double nut the studs in order to back them out.
I did just as Wayne's book suggested, small clockwise turn to break loose the bonding inside the threading and then through the use of some sweet talking using some very creative explicitives and slowly turning the nut, I got all 24 out w/out issue. I measured several along the way before removal to make sure I had a good data base for how far to screw in the new studs.
I think I spent more time cleaning out the treads than it took getting them out but by the time I was finished, they screwed in with next to no effort.
As you can see, they was a lot of gunk in the threads.
At this point. I'm ready to take on the challenge of getting the cylinders back on.
Mike
'89 CARRERA
#402
Old 03-28-2015, 02:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
non-whiner
mreid's Avatar
I would have removed the Pistons with the cylinders. Trying to hold the piston, compress the rings, and press the cylinder back on multiplies your chance of breaking a ring and not knowing it. Plus, aren't you going to replace the rings?
"Too much is just enough."
Old 03-28-2015, 02:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Now the part I was not looking forward to... reinstalling the cylinders. But first I needed to get a tool. After a lot of searching online and talking with some mechanics I decided to buy the Hazet tool. Holy crap that thing was pricey! But like my wife said, spend the money now right the first time or spend it twice wrong. I hate when she's right.
Once I got the tool set up I was ready to go, or so I thought. Since this was my first time doing it and all I had was my rebuild book and the Internet to show me the light, it was slow going.
On this particular pic I think I put that stupid tool on the piston a good two dozen times because either the ring would not go into the cyl or the top ring would pop out of the band for the tool. Talk about frustrating, I was ready to blow the damn thing up. Four hours later this is what I ended up with
After all that I put into it, I now feel like I have to take the cylinders back off because on a few of them going on, there were some loud popping type sounds that happened as the cyl when down over the rings. I was reading that if a cylinder doesn't feel like it the others then you should investigate what was going on. I really don't want to find anything when I remove them but I will feel like I just saved my own ass if I do see something.
Mike
'89 CARRERA
#402
Old 03-28-2015, 02:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Since I'm going to take the cylinders back off, yes I'm ordering a new set of rings. I was actually considering taking the pistons off and taking them down to the shop for a good cleaning. Probably would not hurt getting rid of 25 years worth of carbon build up.
If I've learned anything during this adventure it's been the appreciation for how these engines are put together because this whole thing started out as all I wanted to do was install some cams and change my exhaust. Now look where I am, I never thought I'd go this far.
Mike
'89 CARRERA
#402
Old 03-29-2015, 01:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
I really didn't want to take the cylinders back off because it was such a pain in the ass getting them on the first time I'm sure it will be the same pain the second time but I took them off. Luckily I did not break any piston rings but I did find something that made me glad I took them back off nonetheless.
This is what I found:
All those shavings must have come from the headbolt stud holes. I thought I I protected them but I guess not as good as I thought.
I took every down to the shop and had run the cylinders and pistons through the parts washer for a few cycles just to make sure I have them clean enough. The replacement piston rings came today from Porsche so maybe now I can restart putting things back together.
Mike
'89 CARRERA
#402
Old 04-02-2015, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Racer
preston_brown's Avatar
Did you use a thread cleaning tap, or a thread cutting tap? Looked like a cutting tap.
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 04-03-2015, 06:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Racer
Thread cleaning / chasing taps look like this:
Preston Brown
Old 04-03-2015, 06:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
safe's Avatar
I wouldn't have used a tap to clean the threads.
I would also have installed the pistons and cylinders before the studs, much easier.
Magnus
Old 04-03-2015, 08:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Woulda, shoulda, coulda...I'm learning. I've taken my time to be very careful not to mess something up, and when I've come across an area where I was unsure about it, I have stopped and gone back and made sure I understood what was going on so I didn't make more of a problem than what I already had. This may be my first time doing this but I can already see certain things where I would have done things slighty different. Take the cleaning of parts/hardware for example, the way I have done it was take all my stuff into the dealership clean the parts throughout the day, haul all the stuff back home and try and build some momentum again. Next time I think I would just buy a parts cleaner for my garage so that I would not have to stop, this would become especially handy when you have some momentum and are making progress. That's just one example of how I would do things differently.
The best news I received all week was my car is getting close, we now have primer and paint is coming soon. Fingers are crossed for end of May. It's looking like I might just get back to the track this season. I'm really excited!!!
Mike
'89 CARRERA
#402
Old 04-04-2015, 12:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Is there anything I could do to remove this carbon or should I not even worry about it knowing it will return after a few drive cycles?
Mike
'89 CARRERA
#402
Old 04-04-2015, 03:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Project Addicted
How thick is it??? It can me cleaned pretty easy and I clean them before installing.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 04-04-2015, 04:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Tag the pistons, remove excess oil, then overnight soak in a bucket of fresh carb cleaner with or without the rings, or glass bead. Be careful not to blast the ring lands. Don't be too quick with the putty knife.
Sherwood
Old 04-04-2015, 08:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
After they ran through multiple cycles of the parts washer at work they came out a lot cleaner than what I started with. All the oil has been washed away on the pistons. What you see in my last pic was probably the worst of all six. I could take them to the shop and use the bead blaster on the tops if I was to be super anal. I suppose I could tape the outer walls of the pistons to protect them while inside the cabinet. Just out of curiosity, is there any advantage to doing something like that vs putting them back in the way they are with a little crust otherwise very clean?
Mike
'89 CARRERA
#402
Old 04-04-2015, 11:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
The degree of being anal is up to you. Obviously, the engine worked fine with the existing crust. Some anal questions/factoids:
What's the problem with removing carbon from engine parts already removed?
How thick is the carbon crust? Thickness provides variable compression ratio differences between cylinders, albeit minor, but nevertheless, different.
Carbon crust will inhibit heat transfer and thus increase exhaust gas and chamber temperature
Carbon can, depending on operating conditions and engine parameters, glow red and create pre-ignition conditions.
Carbon can flake off and migrate between valve and valve seat, piston and cylinder. Loose flakes are more prone to glow red (see above) and encourage more carbon buildup.
Carbon flakes could migrate to catalytic converters downstream.
OTOH, carbon can also be scrubbed from combustion chambers by running the engine at high idle and introducing a fine water mist into the intake. However, not easy to monitor extent and effect on combustion deposits.
https://www.google.com/?gws_rd=ssl#q=effects+of+water+mist+engine+cleanin g
Sherwood
Old 04-04-2015, 11:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
I would bead blast them,just something I always got in the habit of doing,makes me sleep easier at night.
Old 04-04-2015, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
It's a relatively thin layer, probably between .25-.5mm thick at its thickest point. Yes Sherwood you are correct, it was a perfectly running when I took it out before I took the body down to be repaired.
Mike
'89 CARRERA
#402
Old 04-04-2015, 04:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
