-   -   milling the bottom of cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/822444-milling-bottom-cylinders.html)
carl74344 07-25-2014 07:52 PM
I have seen this a few times now. why would you do this? is it something I want to do? is for oil flow?
http://forums.pelicanparts.com/uploa...1406343028.jpg
HawgRyder 07-25-2014 09:54 PM
Extra clearance for a longer stroke crank?
Or maybe the owner changed rod type and needed more space to swing them?
Bob
carl74344 07-26-2014 12:32 PM
so for a stock motor no real value. would it help oil flow? it would be easy to do.
911pcars 07-26-2014 01:03 PM
A modification to minimize air flow restriction as piston moves toward BDC. Supposedly saves/gains X HP in high revving engines to extract max. power. YMMV.
Sherwood
Walt Fricke 07-27-2014 10:44 PM
This is often called "mooning" the cylinders. Goes along with profiling or otherwise narrowing and smoothing the tops of the main bearing webs. Race motors only, really, where cost/benefit holds much less sway.
