carl74344's Avatar
milling the bottom of cylinders
I have seen this a few times now. why would you do this? is it something I want to do? is for oil flow?
1982 guards red 911 sc work in progress
Old 07-25-2014, 07:52 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Extra clearance for a longer stroke crank?
Or maybe the owner changed rod type and needed more space to swing them?
Bob
Bob Hutson
Old 07-25-2014, 09:54 PM
carl74344's Avatar
so for a stock motor no real value. would it help oil flow? it would be easy to do.
Old 07-26-2014, 12:32 PM
A modification to minimize air flow restriction as piston moves toward BDC. Supposedly saves/gains X HP in high revving engines to extract max. power. YMMV.
Sherwood
Old 07-26-2014, 01:03 PM
Walt Fricke's Avatar
This is often called "mooning" the cylinders. Goes along with profiling or otherwise narrowing and smoothing the tops of the main bearing webs. Race motors only, really, where cost/benefit holds much less sway.
Old 07-27-2014, 10:44 PM
