-   -   What have you done for holding the plug wires (http://forums.pelicanparts.com/911-engine-rebuilding-forum/824742-what-have-you-done-holding-plug-wires.html)
panelbilly 08-10-2014 09:58 AM
What's the cleanest way to manage the plug wires. I'm after a clean look. Is there an aftermarket kit for holding them neatly in place?
fred cook 09-05-2014 05:07 AM
Plug wire organizers........
The ACCELL company makes a kit that comes with an assortment of clip on wire organizers. Each clip will hold 2 wires. The wires simply press into place on the plastic holders. They work well and are not expensive. Look in your local auto parts store or hot rod shop.
Hotrod911T 09-06-2014 10:21 AM
I did something similar for my 3.2SS.
http://forums.pelicanparts.com/uploa...1410024084.jpg
GT2BH 09-06-2014 12:26 PM
^^ Thats what I want - where can I get something like that?
panelbilly 09-06-2014 01:18 PM
I need to find one of the metal plates that clamp the wires down too. I picked up my engine in a partly disassemble state and didn't get one of those.
Hotrod911T 09-06-2014 01:30 PM
The wire separators I used are Taylor#895-42700. The kit is sold by most speed shops and online high performance parts outlets. The kit is intended for a V8 engine.
Rod
GT2BH 09-06-2014 11:33 PM
Rod
Sweet, thanks.. great looking engine btw
Gordo2 09-07-2014 05:30 AM
Electromotive XDi Plug Wire Organization
Here's a link to what I did for plug wire organization: http://forums.pelicanparts.com/911-engine-rebuilding-forum/785959-gordos-3-2l-engine-rebuild-ready-reassemble-4.html
I like these connectors - simple, rugged and hold things in place. Sold for 6 cyl engines and relatively universal (by plug wire size).
They also came with mounting brackets that I didn't use (to mount wires upright on an attachment point on the engine).
Best of luck.
Gordo
Walt Fricke 09-07-2014 04:56 PM
When you want to attach these wire separators to something (in my case, the chassis - I have the coil packs chassis mounted, and pull the plugs out when R&Ring the engine, but you could make up things to bolt to parts of the engine also), use a separator with one more groove than your wires. So use a 4 wire separator for three wires, etc.
Then weld (or otherwise fix) a stub of steel tubing of suitable diameter as a fixing point. Clamp the separator to the tube. Works great.
http://forums.pelicanparts.com/uploa...1410134011.jpg
http://forums.pelicanparts.com/uploa...1410134042.jpg
Here's a really low buck method I once saw: wrap the wires (let us say three of them) loosely with a tie wrap. At each space between two wires wrap a short tie wrap around the crosswise tie wraps. Tighten to taste. Now you have your wires bundled flat, but separated by the width of a tie wrap.
Sorry, no picture of this. Good to keep in mind, though.
911pcars 09-09-2014 12:28 PM
If you want to be racy:
http://forums.pelicanparts.com/uploa...1410290857.jpg
I think available from our host and from other sources if not.
Sherwood
