roadster49's Avatar
hooking up driver side hoses to engine
There are two hoses that I need help with.
One is from the fuel cannister on the passenger side of the engine bay. It is a cloth wrapped hose and comes across the to the driver side of the engine.
The second hose is also on the driver side. I am not sure of its origin.
My question, which hose goes to the line with a "T" near cylinder 2?
Which hose goes closer to Cylinder 3
Here are the photos as I think they go, but wanted to make sure before I tightened the clamp.
Thank you.
Old 08-24-2014, 07:49 PM
roadster49's Avatar
Here are some better pictures
Old 08-24-2014, 08:17 PM
The covered 13mm hose goes to the side of the air box, there is a nipple for the connection.
Burns off fumes from the canister on the right side fender wall
Bruce
Old 08-25-2014, 03:14 AM
roadster49's Avatar
As always, thank you.
As I understand, the hose from the charcal cannister (cloth wrapped) goes into the driver side of the airbox (done) and Hose 2 from the gas tank is the return hose and goes into the CIS plumbing.
I am getting ready to fire her up after a "too" long rebuild.
Old 08-25-2014, 06:28 PM
