johnhedge's Avatar
Tools etc.
Hi,
I own a 1990 964 but that hasn't stopped me from reading your excellent document '911 Engine Removal' with great interest. Most of it would apply to me, I guess.
I also bought the P-fix-it DVDs from you. Another source of highly recommended information and presented in a really good way for the novice; me.
This brings me to my question: I've seen a number of lists for the parts required but I've not come across a definitive list of tools and accessories that someone, starting from scratch, would need to acquire. Can you point me to such a list, please?
TIA,
John
Old 09-10-2014, 11:41 PM
Hi John, I have not seen a list. It would help to know what you plan to do. If you are just doing oil changes and basic maintenance, very little is really needed. If you get into engine rebuilding etc, then a few Porsche specialty tools will be required.
Old 09-11-2014, 09:39 AM
Walt Fricke's Avatar
John
Somewhere someone who is into lists must have done this. I've seen lists of tools you ought to have or might want to have in your car, in case something which could be fixed on the spot breaks or fails while on the highway.
As to mechanic's tools, who is going to want to list the metric size sockets and wrenches you might want? We accumulate tools, and when we run across some size we don't have (steering wheel nut, or alternator pulley nut) in a standard 6mm to 19mm set we bought at some point, we add the new size.
For most engine building procedures, if there is a special tool you'll see it mentioned in the factory manual, or Wayne's book, or someone else's book.
I think I have about as many socket type tools that I seldom or never use as I have of the ones I use with some frequency. U jointed sockets seemed like they'd be great when I saw them in a catalog or at a tool store. Still in the tool box, but not used. But someone else may use one or more of these all the time.
So don't hold your breath for anyone to tell you what you should purchase in the abstract.
Old 09-11-2014, 03:19 PM
Turbofrog
smurfbus's Avatar
Pelicans engine rebuild wizard to the rescue: It has tools, HW, books and so on listed in it.
Porsche 911 Engine Rebuild Wizard - Step 2: Your Tool Box
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-12-2014, 02:09 AM
