CA central coast shop recommendations?
I took my 83 SC Targa , 150kmi in to Garage One in Carpinteria CA - due to a no start issue. turns out the CIS box failed- had it rebuilt, and then learned of 2 broken head studs when doing a valve adjustment. I can't afford to do the whole motor - it's dry, and ran really well for 150koriginal mi. I want to drive my car and not park it till I can save 10-15k$ for a whole motor done right so Marlin there said he could just drop the motor , do the studs and possibly a valve job ( if guides or seats look bad ) and put it all back together and it should be a good driver ( albeit still with 150 k mi.) This is all going to cost me ~ 3- 4.5 k$ for all new studs ( Supertech ) and possible valve job & clutch. I could do this myself ( never done a Porsche though ) but have no time or space to do it.
The motor and trans are original and motor is dry, but the trans leaks a bit.
Does anyone have any advice on either Garage One or if I am just wasting my time and money doing a partial job ( though it's all I can afford for a while.)
Thanks to the community knowledge in advance
Old 09-29-2014, 08:07 PM
Max Sluiter
Flieger's Avatar
Where are you located? I consider Carpinteria So Cal. If you are in San Luis Obispo or something there are a few more options like SGS. Monterey I am sure they are there but probably priced like everything else there. I think there are some places in Paso too.
Unless there are other things wrong I would probably go with just replacing the studs and drive it.
Old 09-29-2014, 08:41 PM
moneymanager's Avatar
Go to Schneider ******** in Santa Barbara. The shop you have been using is generally regarded as expensive and incompetent.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 09-30-2014, 06:49 AM
Max Sluiter
Flieger's Avatar
Yes, if you are in Santa Barbara then I would second the recommendation for Schneider A u t o h a u s.
Old 09-30-2014, 07:26 AM
