-   -   Torque supertec nuts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/833344-torque-supertec-nuts.html)
Neffets 10-09-2014 12:01 PM
I have just installed the camshaft housing on my 2.7 with supertec headstuds.
Went off to the shop to buy a 14mm 1/2" 12point socket, came home and it doesn't fit.
Interference with the housing...
So what do you guys use, 3/8" with a universal socket joint and then to the torque tool? A flexible joint?
safe 10-09-2014 01:36 PM
1/4" 12 point socket. or it might have been a 3/8...
DSPTurtle 10-09-2014 03:06 PM
A 3/8" 14mm 12 point works like a charm. You can get a thin wall. I don't remember needing a flex joint with the set of Supertec studs I did earlier this year. A 1/4" will work, but you may have to special order a 14mm in 1/4".
Neffets 10-09-2014 03:38 PM
3/8" did it without a flex joint, I had one of those desperate moments there hehe :)
I got a friend to drive to his garage and pick up all the 3/8" parts he had late in the evening.
