It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Fan housing extension cool drivers side bank?
Is this the correct orientation for this? There was not one on it when I bought the car. The fan is sitting on its bottom as it would be in the car. Thanks.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Last edited by Speed Buggy; 11-01-2014 at 09:37 AM.. Reason: Make title a question...added a ?
Old 11-01-2014, 09:34 AM
You have that correct. Is that part available anywhere?
-Andy
Old 11-01-2014, 11:17 AM
It's a trap...
I got it here (Pelican). I'll post the part number.
Old 11-01-2014, 04:22 PM
It's a trap...
Part number - OEM-91110605501
Fan hsng extension
Old 11-01-2014, 04:40 PM
Not correct,
The fins should lead the air to the oilcooler.
So i think you must rotate it 180 degrees
Michael
Old 11-06-2014, 09:14 AM
tharbert's Avatar
I think that's only 90° clockwise as viewed in the photo. Should direct air down and to the passenger side as the oil cooler is passenger side, I believe.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-06-2014, 09:48 AM
safe's Avatar
It's correct in the picture. I believe it only fits one way.
Magnus
Old 11-06-2014, 10:21 AM
Nope!!!!!
Originally Posted by michelko View Post
Not correct,
Michael
Micahel,
Rotating the air diverter 180° is not feasible because of the engine fiberglas shroud. It would not even fit doing the way you suggested.
Tony
Old 11-06-2014, 11:02 AM
Not correct,
Michael
Hi and sorry i hink i have to correct my statement.
Its orientated the right way in the picture.
Never the less , as far as i remember it fits only one way under the shroud.
Try it.
Michael
Old 11-06-2014, 11:20 AM
SCadaddle's Avatar
That's strange, I coulda swore the one on my 82 SC had the rectangular cut out for the voltage regulator on the bottom and the vanes were oriented same as depicted but certainly didn't cantilever over the rectangular opening.
Like this one:
http://bethnrayndogs.com/car_docs/Porsche/porsche/Porsche_Tech/Porsche_TECHNICAL_BOOKS/Tech_Bulletins/Group27_82-02.pdf
Old 11-06-2014, 02:53 PM
The notch is at the top and bottom depending how the production ran. But you don't see them on the side....
The picture is correct in post one. The only time you see a air guide on the right is in a turbo cowl, it's there for the cylinder 4.
Bruce
Old 11-06-2014, 04:04 PM
