-   -   are these 930 piston usable? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/837928-these-930-piston-usable.html)
ertech 11-09-2014 06:25 PM
Hi guys rebuilding an engine and here are what 2 piston look like.can I still use them if I deburr theme?
My original Pistons are (++) the spare ones I have are (--)
2-Is the only difference weight?
3-If I remove a little material from the ++ and match to the -- should I be ok?
Erick
http://forums.pelicanparts.com/uploa...1415586110.jpg
http://forums.pelicanparts.com/uploa...1415586142.jpg
http://forums.pelicanparts.com/uploa...1415586299.jpg
NICE 69 S 11-10-2014 02:42 PM
As long as none of that metal protrudes out from the circumference of the piston, file it off and use it. Looks like someone was a little careless handling those pistons.
Bob B
