-   -   Rebuilding a 901/16 engine 2.0 1969 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/841410-rebuilding-901-16-engine-2-0-1969-a.html)
Gastoul 12-04-2014 06:18 PM
Hello, I been searching All around the world for a set of piston and cylinder for my engine, but apparently they are no longer in production. My engine is a 901/16 with a compression ratio of 8.6:1. My car is a 911 t manual karmann coupe from 1969. The pistons are diameter 80 mm. I have been offered pistons and cylinder set that have a compression ratio of 9.5:1. I observe that the shape of the piston is completely different, so I am concerned that it won't be compatible with my cylinder head. Can someone help me an give me some guidance with this. Thanks.
Steve@Rennsport 12-04-2014 07:52 PM
Hi,
The original iron cylinders, and even Biral ones are NLA; everything from Mahle is all Nikasil which is really a good thing.
The main thing for you is making sure that your pistons are for the '65-'69 deep-chambered heads, NOT the '70-'73 shallow chamber ones.
If you post a picture of the ones you've been offered, it will be much easier to ID them and tell you if they will work or not.
MaRu 12-05-2014 03:01 AM
Could there be any problems with using Nikasil cylinders without having piston oil cooling?
tom1394racing 12-05-2014 04:28 AM
I have 2.0T pistons and cylinders. PM me for details.
Gastoul 12-05-2014 07:21 AM
http://forums.pelicanparts.com/uploa...1417792867.jpg
http://forums.pelicanparts.com/uploa...1417792897.jpg
this are my original pistons
Gastoul 12-05-2014 09:55 AM
http://forums.pelicanparts.com/uploa...1417802067.jpg
These are the one that someone offered me
Steve@Rennsport 12-05-2014 05:38 PM
Those pistons looks like they were made for the later (2.2-2.4) heads and will not fit your early ones without a lot of machine work (never a good idea).
Gastoul 12-06-2014 04:55 AM
hello Steve, thanks for the reply . the manufacturer ln engineering has taged this set as this "Porsche 911 914-6 2.0 80mm Nickies inc. 9.5:1 JE Piston set" do all of the cylinder heads of the 2.0 lt engines are the same or they are different depending the compression ratio? thanks.
Gastoul 12-06-2014 05:15 AM
what can you suggest me to do with my engine?
Steve@Rennsport 12-06-2014 11:23 AM
The heads are all the same; only valve & port sizes differ. CR is determined by pistons.
I could make a hundred suggestions, but everything depends on your budget, performance expectations, and how the car will be used. :) :)
If you want detailed assistance, take a look at this: Performance Consulting | Rennsport Systems | Porsche Performance Systems and Support
Gastoul 12-07-2014 07:31 AM
Thanks for all the information. One last question, are this pistons more adequate? http://forums.pelicanparts.com/uploa...1417966250.jpg
Steve@Rennsport 12-07-2014 08:28 AM
Those are 2.0 P/C's and will work just fine with your 2.0 heads. :)
