-   -   help finding the right piston rings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/842066-help-finding-right-piston-rings.html)
alfaomega 12-09-2014 08:22 AM
Hallo
Can someone tell me which piston rings to use, on old Cosworth Pistons 95mm for Porsche 911 3,2 Part nr. PA1232.
http://forums.pelicanparts.com/uploa...1418142115.jpg
Walt Fricke 12-14-2014 05:13 PM
Just measure the ring lands on your pistons, and talk with the supplier you use about what you need. These will be in millimeters, most likely. You'll come up with something like 2mm, 2mm, 4mm.
alfaomega 12-15-2014 06:41 AM
Thanks, the old rings is 1.5-1.5 and 4.0 mm
chris_seven 12-15-2014 09:29 AM
Sounds like standard 3.0 Turbo Ring Pack.
Should be available from our host at around $25 per pack - Goetze rings.
Deves also make them but I have never used Deves rings.
alfaomega 12-16-2014 04:09 AM
Thank you, Chris
