help finding the right piston rings
Hallo
Can someone tell me which piston rings to use, on old Cosworth Pistons 95mm for Porsche 911 3,2 Part nr. PA1232.
Old 12-09-2014, 08:22 AM
Walt Fricke's Avatar
Just measure the ring lands on your pistons, and talk with the supplier you use about what you need. These will be in millimeters, most likely. You'll come up with something like 2mm, 2mm, 4mm.
Old 12-14-2014, 05:13 PM
Thanks, the old rings is 1.5-1.5 and 4.0 mm
Old 12-15-2014, 06:41 AM
Sounds like standard 3.0 Turbo Ring Pack.
Should be available from our host at around $25 per pack - Goetze rings.
Deves also make them but I have never used Deves rings.
Old 12-15-2014, 09:29 AM
Thank you, Chris
Old 12-16-2014, 04:09 AM
