JClanin
jclanin's Avatar
Send a message via Skype™ to jclanin
Transmission 'chatter' - time for a rebuild?
Hi all,
I'm noticing what I would call transmission or gearbox 'chatter' in lower revs when driving my '87. Once the revs come up and the engine and trans are under load the 'chatter' immediately goes away.
I'm thinking it's time for my g-50 to be refurbished. 117K on the clock. What do you guys think and what am I potentially looking at here?
thanks!
Jim
Old 01-11-2015, 01:28 PM
Josh D's Avatar
When was the last gear oil change? If it's been awhile, I would start there. 117k doesn't seem like a lot of miles for a G50 (or a 915 for that matter).
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 01-11-2015, 03:04 PM
Originally Posted by jclanin View Post
Hi all,
thanks!
Jim
Jim,
Based on experience, your transmission may not need a thing (unless the syncros are weak @117K). The noise you hear is 100% normal and due to backlash so you only hear it at low RPM.
If its not grinding when you select 2nd or 3rd gear on the up or downshift, just keep driving it and save your money for when you DO need a rebuild.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-11-2015, 04:37 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The G50 is notorious for bearing grumble as they continue to get older. Agreed with Steve. Keep on going until it has more immediate needs related to crunchy gear selection.
Kevin L
'86 Carrera "Larry"
Old 01-12-2015, 08:08 AM
JClanin
jclanin's Avatar
Thanks guys!
Old 01-12-2015, 11:39 AM
