Wiring diagrams 1976 911? Specifically horns!
hey all -
been looking all over the place and I cannot find a wiring diagram specific to the 1976 model year 911s.....there are 1975 wiring diagrams, and 1977 wiring diagrams, but is the 76 a transition year that did not get well documented?
I have no owners manual, Haynes leaves out the 76 model year as far as I can tell, and a search here has not helped....
to further complicate matters, the car has been converted to a 1989 3.2L power plant, so lord knows what the electrical permutations were to get that to work?!?! Dink Farmer did the conversion, who has a pretty good reputation as far as I can tell.
Trying to get the horns to work, flying a bit blind at the fuse panel. I have 'clicking' in the relays when the button is depressed, but no noise from the horns. I swapped the relays around - same result. Jiggled all the wires at the horn connections - they are cruddy but appear to be solid on the attachment points.
The later horn diagnostics are somewhat useful, but I'm not sure what I'm working with - they do not appear to be the 964 horn configuration judging by the pics....
any help appreciated - as always!
cheers
tom
Old 01-04-2015, 03:52 PM
ugh, apologies, wrong forum. sigh
Old 01-04-2015, 03:53 PM
Horn wiring diagrams........
Originally Posted by tadink View Post
hey all -
cheers
tom
Tom,
Where have you been looking for the wiring diagrams? The wiring diagrams for the horns circuit for '75, '76, '77, and SC's ('78-'83) are all identical. They have not changed a bit. Check if you get power to the relay and the relay is working.
Tony
Old 01-04-2015, 06:40 PM
