84 911Valve adjustment
Hi
I need to know the valve adjustment clearance for my 1984 Porsche 911 targa. and the tool I need to make this job, any other suggestion to verify my motor? now the engine is open to change damage valve how I increase HP increasing the pressure? The car for a bad gears set at high speed from 3rd gear at 100mph changes from 3rd to 2nd making a over rpms Last edited by hyperkinesis; 12-28-2014 at 06:07 AM.. |
Are you saying you money shifted and want to know if a valve adjustment will fix the damage?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Air Medal or two
Trying to understand your post -
The valve clearance will be the same no matter what else you may do to the engine.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I need to know the correct valve clearence
.1 mm
