2.2t - efi?
Hello,
presently have a '72 2.2T in my '74 with Webber 40's on it. Recently started collecting parts for a 3.2 swap+turbo, but it's looking like I might not have everything ready for spring. I've already got my engine management and intake (Haltech platinum sport 2000, and a 3.2 intake, fuel rails, and injectors, MSD ignition) Is there much to be gained out of a 2.2T if I were to swap the carbs for the 3.2 intake and use the standalone ECU?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
Turbonut
Much better driveability and gas mileage, assuming someone (yourself?) tunes it. Also probably a bit more power, just quessing it would be in the region of 10%...
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
You should also have better idle (w/ and w/o accessories), better start (cold, warm, and hot), safer operation at higher RPMs, and your car won't smell so strongly of gas. I'm laying out a plan to do the same with my '69 2.0T.
So far, I'm looking at MS3 with fully sequential coil near plug ignition and injection. The top side will be replaced with fuel rails, injector bodies, intake runners, and a plenum. The dizzy will also be replaced with a camshaft sensor and a 60-2 gear will be added to the crankshaft to control ignition timing.
Erik __________________ 1969 911T 2.0L Coupe 2014 Jetta TDI SportWagen |
Turbonut
911T cam is so mild that there will be no issues running it with common plenum intake..
Black,
What would be a better alternative for the T cam on a 2.0 or 2.2 that has been converted to EFI with a common plenum? My plan was to fabricate a custom intake. It would have a single or dual plenum and throttle body (not decided yet). The intake runners would be equal length and sized for the smaller displacement engine.
Thanks for all the input! I am absolutely a beginner, all I've really done is regular maintenance for the most part, suspensions, brakes, oil changes, etc.
It absolutely would be a great idea for me to just pay a shop to do it, but this is a hobby for me, and I'm just doing it because I want to: for fun. Being up here in western Canada, parts availability has been a PITA, looking more and more like I'll need to just have a motor shipped up from down south. I'm just a bit excited to play with the new ECU I picked up. The initial idea was to keep the 2.2+webers on the shelf, and I've collected parts for an EFI conversion on a 3.2, but purchasing a good long block has been more time consuming than anticipated.
Turbonut
Some years ago we installed Megasquirt to a customers 2.2E engine and it was also done using custom common plenum. No issues whatsoever, car ran like a charm.
So I would say go for it, but may not be worth it if you must make the 32mm vs 40mm intake difference to fit because you are not planning to keep the EFI on 2.2T, right?
gearhead
I say leave it be. Enjoy your car while you get the 3.2 together. One project at a time. I spread myself too thin, get cars in pieces and then don't have anything to drive in the now.
TurboKraft Inc : Carrera Intake Manifold Adapter Set Regarding the reversion problem, this refers to exhaust gasses entering the intake plenum due to the intake valve being open before the piston hits TDC? so ITBs might mitigate the issue of having exhaust gasses enter the common plenum, but with the Carrera intake, are the intake runners not about the same length as the carb+velocity stack? Are EFI/turbo cams ground to have the intake valves completely closed until TDC or something? (Pardon my ignorance)
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html Last edited by Bergo; 01-07-2015 at 12:49 PM.. |
